Hi
On my 300TDi SW it's a steel bash plate covering a steel tank and should seperate.
When mine leaked it was from little stones/gravel/sand that had worked their way between the tank and plate, got caught in that dimple on the bottom and wore a hole in the tank.
When I replaced the tank I drilled a large hole in that dimple to allow an exit point for any caught debris. Time will tell.
You should be able to get the tank patched for about $120.
