The 2.25 petrol motor originally came with a Solex, replaced about 1967 by a Zenith, which was in turn replaced some time in Series 3 production by a Weber. In good condition there is probably little to choose between them. The Solex seems to be getting hard to find parts for, and its operation is difficult to understand for most mortals. The Zenith you can get parts for but does have a few points to watch. I have no experience of the Weber. Both Zenith and Weber are available new.
The most common "foreign" carby fitted is a Stromberg off a Holden six (cheaper and easier than fixing the original). While some users are happy with these (particularly if modified to better suit the engine), they seem to have little advantage over the original carburetters and have the drawback that they do not like steep angles, although I have heard this can be fixed.
There are occasional references to the use of a side draught SU, which is reported to give markedly improved performance, but this requires a special manifold. I have not heard of the type you refer to being fitted, but being two barrelled I would expect it would need substantial manifold modifications if not a new manifold, even if it is suitable.
Hope this helps,
