Results 1 to 10 of 11
Thread: Warn Winch Motors - Will a 6hp fit?
    Jock The Rock Guest
    Gday
    I'm currently rebuilding an XD9000 Warn winch
    I'm after a new motor for it, I'm pretty sure it came standard with a 4.6hp motor
    Will the larger 6hp motor bolt straight on?
    Jock The Rock Guest
    Bump
    NSW far north coast
    I think this was discussed on Outer's a few years back ?
    Might pay to do a search there ?
    Hi Jock,
    It depends on the year from memory. They changed the input gear in the housing but I can't remember the exact details
    if it had the 4.6hp standard I think it will as I swapped the 6hp from an xp onto my 8274-50 which had the 4.6hp motor.
    Pete
    99.87 MB
    As far as I'm aware the XP9.5 or 9500 (???) is just an XD9000 with a 6hp motor.
    I think the motor does just go straight on, and all of the warm motors are interchangable, but the 6hp is pretty big and you may find the winch when mounted is already up against the chassis rail with the 4.6hp, yet the 6hp being longer wont fit.
    Slunnie
    Jock The Rock Guest
    Thanks for your posts, I may just stick with the standard motor
    If the difference in the input gears is only the motor shaft being keyed (early) or splined (late) then they should interchange (they will on the 8274 and the motors aree the same) and so the motors should interchange also but the length is in question.
    Eastern Suburbs, VIC
    You can buy the input gear which will allow an older winch to take the newer motor. Check eBay.
    1986 Range Rover Hiline
    2004 D2 TD5
    Sep 2011
    templestowe vic
    I can call warn while I'm at work tomoz and find out if u like?
    Aug 2008
    Kuala Lumpur, Malaysia
    I got the manual if you want it
    SERVICE MANUAL
    FOR THE
    Warn
    Mid-Frame Winches
    M-6000, M-8000, XD9000
    12V DC
    Electric Winch
    5.33 Mb as Warn US sent it to me a few months ago (very helpful buggers at Warn)
    I wish the 8274 manual had the same detail.... but at least covered on the internet
