Thread: Rear latch stuck on 110
    Mar 2010
    South East Tasmania
    Just got home and went to open back door on our 110and latch was stuck!
    There is nothing stuck in the lock, and I have pulled the door skin off and can't see why it would be stuck.
    Kingston, Tassie, OZ.
    Quote Originally Posted by butundede View Post
    Hey Bob,
    The possibilty is that the central lock actuator rod etc MAY be the problem, did you get the trim off with the door shut? Did you try the key in the barrel, does it feel normal?
    JC
    Jul 2011
    Yarrawonga, Vic
    Meybe the latch being stuck is not so bad after all
    When I saw this video I thought what idiots, then I felt sorry for the bloke after his wife will be finished with him.
    still idiots tho
    [ame=http://www.youtube.com/watch?v=2JoTJBRIhdA]TOYOTA and DEFENDER in climb - YouTube[/ame]
    Anyhow I'd hate for this to happen, I wonder if its possible to fit a backup latch.
    Mar 2010
    South East Tasmania
    Hey Bob,
    JC
    Actuator rod is moving fine, got the trim off no worries. Key won't turn in the barrel. Not feeling normal.
    Have you got time to drop by tomorrow?
    JC
    Feb 2011
    Brissy
    How old is the the car, the reason I ask is my new D90 which I brought early last year would do the same. CL would work ok the key would work but the handle was locked solid.
    I used a combination of the two several times and it would suddenly work.
    I also had a problem when I closed the rear door, it would not quite shut properly at the top of the door, which I was going to get sorted at its first service then all of a sudden the door seemed to bed in and close completely shut and no longer has door handle jam ( I use the rear door alot for work gear) .
    I got it looked at anyway on its first service, which they made "adjustments" aparently.
    This may or may not have a bearing on your problem but has to be a first for a self fixing Defender fault...
    It may be the latch just needs a release adjustment, hope this helps.
    G
    Mar 2010
    South East Tasmania
    JC
    Working tomorrow, but I am coming up to town on Friday if that's ok?
