Results 1 to 9 of 9
Thread: UHF antenna's ???
    South Sydney
    UHF antenna's ???
    I have a GME TX 3400 UHF in my 98 Disco, it currently runs through a cheapy fibreglass aerial, about 900mm long mounted on the guard, i have put a winch bar on the car and now want to move the aerial, but as this is such a cheap and poor quality aerial (low power) i have decided i might aswell get a new one, it needs to be good in rough country, have a spring base, and be fairly tough (for instance a bird strike), my mate has a big white one on his ute, which has stood up to a bird strike, its relatively new so would be a 6.5 dB antenna i think, its about 1200mm long, cost him $220
    Does anyone know a good place in Sydney (south side) to buy aerials, don't mind cost, it will end up on a high country trip so it needs to be pretty reasonable. Also an you recommend a brand, and maybe a model if you have personal experience with a goodun
    Will
    Oct 2007
    wetherill park
    GME have a good range look at the link the google to get the best price most good retailers will post their location dosnt matter too much
    Land - 477 MHz | GME
    BTW with uhf the length of the ant doesnt matter to much but an elevated feed ant on a spring base is good if mounting on a winch bar the thing to think about is do you need high gain or low gain ant IE are you going to use it in hilly country or flat most of the time even get a 3.5 and a 6.5 db to cover both you can get a good set from supercheap with both ant in a pack
    ELEVATED FEED ANTENNA KIT CBA36F1L - Supercheap Auto Australia
    Don't know about the south side but Andrews Communications in Greystanes is good for advice and they have a comprehansice, if not a little disorganised website. Also there's a mob in Perth that run off ebay as well as the web that a few people have recommended in the past as they have really good pricing and a good web site.
    Oct 2007
    wetherill park
    Yep andrews is very good not far from me and I have bought from them also you can but off their web site
    South Sydney
    Thanks fellas, i assume low gain = flat terrain, high gain = hilly (am i right), i had a quick squiz the other day at SCA, but i had always thought their products were lets say the lower end, however if they are supposed to be alright it doesn't worry me if i buy them, where the farm is there is a dense pine forest, along with a mountain range (Weddin), i assume i would just get the high gain as it should do everything, maybe i'll have a look at some 4wding places, Cheers
    Will
    d@rk51d3 Guest
    Low gain for hilly areas, high gain for long flats.
    South Sydney
    I think i've worked out what my problem is, i think i've got a 27MHz antenna from an old CB radio, a newer one is on the cardsd liking the GME AE4705, nice unit
    Oct 2007
    Wantabadgery, N.S.W.
    Mobile One do aerials and are at Camden
    Mobile One Australia Pty Ltd
    Don.
    Feb 2009
    Chidlow, WA 6556
    Prestige communication has some good deals I use them for all my stuff quick delivery and nice and cheap.
    http://www.prestigecom.net.au/
