Results 1 to 6 of 6
Thread: 302w in a 91 RRC Hunter
    rpm289 Guest
    Has anyone swapped a Ford 302 into a 91 RRC with auto tranny? I want to keep the Rover tranny if possible. I have a garage full of 302's
    Thanks,
    Mike
    Somewhere else, QLD
    There is an ongoing thread re Windsor ( albeit a 351) /RRC
    http://www.aulro.com/afvb/projects-t...ic-rangie.html
    The Hunter was US-specific edition. It was a lower spec model.
    See http://www.rangerovers.net/modelspecs/1991.html#special
    rpm289 Guest
    ROVERCARE or peachy80
    Is Rovercare or peachy80 still on here? I found a old thread from 08 about a 302w in a RRC. Had some questions if they are.
    Somewhere else, QLD
    When you want to send a Private Message (Top RH cnr) , you type in the name and the system brings up current members - both rovercare & peachey80 are still members - so if you have a question send them a PM.
    rpm289 Guest
    Cool thanks, I will sent them one.
