Hi Mike - the RRS is the same as a D3 in this regard.  The Europoean standard has power going via the standard European plug to each of the tail lamps individually - in Aust we just have one power lead feedin tail lights and number plate light.  The problem is that one of the European tail light feeds (not sure which one) is the spot that works the trailer brakes.
When I connected my trailer to my RRS (Aust cars are still wired the European way) I did not know about this so when I switched on the lights the trailer brakes came on.
I have not installed a controller as yet so just pulled one of the fuses at the rear that fed the appropriate tail light (brakes).
You will need a controller installed in the cabin that can also be reached by you.  The controller will sent aything from 0v to 12v when you apply the brakes to the trailer and activate the trailer brakes when you apply the car brakes.  The instructions are on here somewhere.  The controller has to be accessible by the driver if the automatic system needs to be overridden.  There are various systems which cost around $150 - $300 - the are two basic types - proportional which applies the trailer brakes proportionally to how hard you apply the car brakes.  The other type applies the trailer brakes irrespective how hard you apply the brakes.
When I install my controller the trailer brake control wire will replace the current appropriate tail light wire on the power side of the rear fuse and I will just replace the fuse and it will all work OK.
