Originally Posted by
langy
Provided that it is a one-button fob, then the solution is to revisit the donor disco and take the harness from the drivers door as well. LR wired the door solenoids up a little different in models without the alarm. The connections are behind the RH footwell, and can be fed thru the door frame one at a time. Whilst you are there, grab the ultrasonic sensors from near the interior light and (if you can) the led harness. Did you get the antenna for the alarm ECU?, as it plays a big part too.
Have a look thru the RAVE wiring diagram for alarm and it should explain it - otherwise PM /post some pics for more info.
