Results 1 to 3 of 3
Thread: 2" Lift Kit
    Feb 2010
    Stellenbosch, Republic of the Western Cape, RSA
    2" Lift Kit
    Gents,
    Got a 2" lift kit from a friend of mine who went to 3".
    Set comprises:
    Bilstein shocks - custom shocks, variably valved and custom damped. Harder on tar than standard, but softer than standard off road. They are also longer than standard, to match the springs.
    Rear: Progressive OME 762 (medium duty)
    Front: Progressive OME 761 (medium duty) + spacers (these are for a Disco1, only give 25mm lift)
    Initial feedback after driving from the workshop back home and to work this working: much better road holding. While the setup is slightly harder than LR setup, it's not bone-jarring. And with the Bilsteins, you don't keep bounding after going over speed bumps - there are many on my daily commute.
    Will have to try them offroad soon!
    Before:
    After
    Feb 2009
    Naks,
    What gear do you have hanging of the front, i.e Bbar, winch and cable type, brush bars.
    Can I ask you what distance you have between diff and bump stops on the front nowdays.
    Jason
    2010 130 TDCi
    Feb 2010
    Quote Originally Posted by newhue View Post
    What gear do you have hanging of the front, i.e Bbar, winch and cable type, brush bars. Can I ask you what distance you have between diff and bump stops on the front nowdays.
    I have a Frontrunner bullbar, but no winch.
    I will have to measure that when I get home this evening.
