Thread: Dust at MAF sensor
    Coogee, South of Fremantle, WA
    Dust at MAF sensor
    Just back from a 2 1/2 day trek driving along the Down Nannup trail, SW WA Half of which was Red dirt roads.
    I was the 3rd of 3 cars so was in a constant fog of red dust on these roads. Now back and doing a post trip clean and check-over I have removed the air filter and Maf and was surprised to see a light film of the red dust on the grill before the maf sensor. The engine bay was absolutely covered in red dust like the rest of the car. I know no amount of dust getting past the filter is a good thing but all looked good seal wise and the filter is relatively new. Any one had similar dust ingression after extreme dust driving.
    Apr 2011
    NSW
    Hi Wayne,
    Have a look at these threads:
    http://www.aulro.com/afvb/discovery-2/91474-dust.html
    http://www.aulro.com/afvb/discovery-...lters-td5.html
    Scarry and a few others have had the same problem and there are a number of options.
    Aug 2010
    Pakenham
    Yes. I tried putting electrical tap & gaffer around the inlet pipe joins with no real success. I think the standard RR filters are simply not made for extreme Australian conditions. It may be worth while spraying the filter with some type of engine oil to suspend the fine dust, I don't know if it will destroy the filter or not having never tried it myself, anyone want to shed some light on this subject?
    Avoca Beach
    No matter how good the air filter is , some very fine dust will get through, and a lttle bit of really fine micron dust probably doesn't do much harm.
    The way I combat it in really dusty conditions is to fit a Uni filter oiled prefilter in the neck of my snorkel in really dusty conditions.
    I did the Tanami, GRR, and up to Kalumburu with this and when I got home to Sydney the filter was still clean, although I had to remove and clean the Unifilter every 2-3 days. They come in packs of 3 so you can rotate them.
    http://www.uniflow.com.au/
    Regards Philip A
    Feb 2012
    The measure of effectiveness of an air filter is not how much dust it traps but how much it lets through. In these terms, a filter which allows 2% of dust through is said to be twice as effective as a filter which allow 4% through.
    I wouldn't be putting engine oil on a paper air filter. I foresee two issues: the breakdown of the paper element and contamination of every sensor from the MAF right through to the O2 in the exhaust.
    Remember that the intake system is under vacuum, so applying duct tape to the outside of joins may be effective (clean them first).
    I also can vouch for the Unifilter. We had them fitted to a few 4wds and heavy machinery in western Qld. I will say that I think people clean them far too much. These things can appear caked with dust and still be filtering OK.
    I've read that the airbox seal can be an issue. I'd start here, firstly with a new seal.
    Good luck - a dusted engine is a horrible thing. I agree with the approach you're taking - fix it, quick!
