Results 1 to 6 of 6
Thread: v8 starter motor failure
    Sep 2011
    newcastle
    Hello all .
    My 3.5 89 model Rangie starter motor failed today . Fortunately I have a spare from my 3.9 with the slipped liner problem and bolted it in and all is good . My question today is , is it a waste of time trying to pull the faulty one apart and try to fix or should I look for a 2nd hand one for a spare .
    mike 90 RR Guest
    Quote Originally Posted by theg View Post
    Hello all .
    It' is ALWAYS a good idea to pull something apart and try and resurrect it
    If your lucky ...it will be just a clean up of the windings and a set of new brushes
    Better than watchin telly
    Mike
    Sep 2011
    newcastle
    new brushes
    Hi Mike .Do you know if replacement brushes are easily obtained .
    May 2008
    Bundaberg Qld
    yes
    Sep 2011
    newcastle
    tips for disassembly
    Any tips for disassembly or simply start undoing any bolts nuts and screws . Work it out as I go ?
    pretty much, heres a hint...
    when its time to assemble the brush packs to the commutator an empty coke bottle will be your friend.
