Results 1 to 4 of 4
Thread: Air Flow Meter Replacement
    Feb 2010
    Hi Guys:
    I've done a bit of an "Intake" Spruce up and clean today.
    Cleaned out Throttle Body, Idle Air Controller etc etc...
    I purchased from the UK a New Air Flow Meter as well
    Link: eBay Australia: Buy new & used fashion, electronics & home d
    I've fitted this, and noticed initially that my Idle was much, much better... however there is an initial hesitation under throttle either at Idle when revving.. or when starting in Drive.
    I went for a 10 minute cruise and it seemed to be getting a little better... I wondered whether its adapting to a "Correct" Air Flow Meter or whether the One I've purchased is incorrect...
    Any Ideas?
    it's usual to reset the 'Adaptive Values" so the EFI system re-learns... otherwise it will take a while to adapt...
    Feb 2010
    Is best method to reset the Adaptive Values in the case of not having a Faultmate or similar to leave the Battery disconnected for a period of time?
    Feb 2010
    Or probably a Nanocom Evo... which I think I'm going to have to purchase now
