Results 1 to 4 of 4
Thread: Brake Warning Light
    Jan 2011
    new england
    Brake Warning Light
    Gday. My brake warning light is on pretty much all the time. I have checked brake fluid and that is always OK. What else apart from low brake fluid can cause the light to come on?
    I am wondering if the sensor itself is crook. Where is the sensor and how is it wired up? There is a light purple wire with baynet clip simply hanging loose in that general area near the master cylinder but I cant see any attachment points.
    lochie Guest
    Wouldbe owner
    G,day.Try brake disc wear,if the light stays on after brake application.Best of luck-Lochie
    Handbrake switch?
    Mar 2011
    Burpengary, QLD
    Are you talking about the handbrake light? I know as it also functions as a warning light that the ABS fuse has been removed (!), so it may be an ABS error (if you have ABS).
    Also the handbrake switch - I snapped mine off on the weekend putting the transmission tunnel back on, which will cause the light to remain on.
