Results 1 to 10 of 17
Thread: no ignition or dash
    Jun 2011
    cairns
    no ignition or dash
    Heya
    I have a 95 P38 HSE
    yesterday jumped in to go to work, remote opened the doors, got in, turned key, had acessories but no dash when cycling through to ignition. got out the car... stood dumbfouned or 20 seconds and hey presto... dash light on and turned the key and away we go...
    got down the road.. dash lights flickering... then she stalled. lights came on a second later and she fired up no problem. drove back home (gave myself the day off too haha) and it flickered (resetting ignition sequence) all the way.
    Played with terminals, checked and cleaned every fuse and relay both BECM and under bonnet. Checked 12V to all three BECM power feeds, ok.
    Checked earth from fuse box, checked earth from BECM.
    Being st paddys day I then slowed the process of elimitation by way of beer.
    Ok, got up this morning...slowly....bloody Jamesons.... and went into the garage. No dash at all and everything I do wont change that. The BECM seems to still be working as the dash will still show ignition key in, bonnet open etc etc etc. However, it also showed ignition key in a few times when the key was out, andthe accessories all work perfectly. there is a clicking in the BECM when the key is turned to start but nothing else, there IS a power drain as the light on the 12v lighter adapter for the retro fitted reverse camera dimms when the key is turned.
    Car has new TRS engine, NEW battery, NEW cables.
    Myabe it's just peed off cos its parked next to a Caterham in the garage.... and its feeling fat or something.
    Any thoughts?
    Or should I just go back to the Jamesons and call a tow truck toorrow?
    Cheers in advance
    Have you put a meter across the terminals? The battery may be new....but is it charged? Any means of jump starting it to see whether more (battery) power is required?
    Jun 2011
    cairns
    Battery is at 12.64V
    Load tester shows good
    all other accessories work, windows, sunroof, seats, sound system etc.
    I can bridge the plug from the key barrel and get accessories but nothing else.
    Will go through the electrics in ws manual at work tomorrow, then bring em home on stick and go through it again. When I bought the RR I made sure I had a second car to get to work in
    May 2008
    Try "rebooting" the BeCM.
    Disconnect the battery for a few minutes, then reconnect.
    You will need to reset the windows, sunroof etc
    I had a 95 model that exhibited wierdness every few months, a reset seemed to fix it.
    Worth a try!
    Cheers, Paul.
    Jun 2011
    cairns
    did the reboot on several occasions, ran multi meter to all power feeds, checked all earths. still no go.
    I noted the BECM powers the ECU and there is power to it, so maybe the ecu has an issue. I have delivered it to the boys at Hypertuned in Cairns and I'm sure they will sort it in due time.
    Will let all know the outcome.
    Coogee, South of Fremantle, WA
    I cant offer any knowledgeable help but have had a thought that this could possible be a fault of the engine ECU. Not 100% sure on this but could be the one behind the battery on gems and eas box on Thor.
    For some expert advice and testing see........Sending your Becm for Test-P38 Range Rover Electrical Common faults and Fixes
    Correct me if I am way off the mark here.....
    Jun 2011
    cairns
    well the hunt is still on.
    new becm, new fuse box (apparently they crack or deteriorate at terminal 19?)
    still no go.
    the boys have got the dash going by forcing it through the becm, but still no dash or power to the engine.
    ordered a new ecu yesterday, be here monday.
    every phone call is costing me lots of money and I don't even get heavy breathing on the other end!!!
    stay tuned
    zhoey Guest
    Sounds like the need for a new fusebox.
    Feb 2012
    Hold on Hammy. New BECM, new fuse box AND new ECU?
    It would appear these guys are having guesses with your credit card. I've had this happen to me with a Falcon (of all exotica!). I was charged $800 to not fix it then fixed it myself with a 2nd hand instrument cluster for $165. I delayed exploding until in front of the autoelectrician. His excuse was "I don't know anything about car computers."
    When something stops working like this, it's usually because something broke/fried. Not half a dozen things all magically failing at once. The excuse usually goes like this "oh well, yeah the fuse box fried, took out the becm and the ecu. Yeah, real bad mate - unlucky.'" See para above where I was fed exactly that crap prior to finding out he knew nothing.
    Has anyone hooked some diagnostics up to your car? Or are they trying to fix it with a test light and a multimeter?
    Quote Originally Posted by Craig_Keira View Post
    X2. Agree with Craig's concerns... people see range rover badges and assume you are made of money. I hope you have mates at this place otherwise that bill could be more than the cars worth.
    Parts for these cars are too expensive to play fix by process of elimination with... there are plenty of tools available to plug in and properly diagnose the cause. Put your foot down with them and find out what they are using to determine the problem before you lose the shirt off your back.
    Tell them you will want all your "bad" parts back, they are still yours and you can use them to check up on the job and often reco (like the fuse box... it can be revived if you are patient). And finally, do not pay for parts unless they were actually causing the problem they are supposed to fix for you.
    Hoo-Roo,
    Dave.
