Thread: KEYFOBS ON EBAY
    KEYFOBS ON EBAY
    Just a quickie, found a seller on eBay called topfobs doing the D2 type key body. Proper body not cheap junk chingwah ones, two batteries and a blank blade for $23.00 including free postage!
    I got it under item # 250881111497
    Mods, move this to the right spot if you need too but IIRC they fit Deefas too(?) so stuck it up here.
    Andrew
    Using Capitals, the difference between helping your Uncle Jack off a horse or helping your uncle jack off a horse...
    Solly Guest
    I bought a set from Topfobs a couple of months ago for my D2.
    Good quality, good price, good service...
    Apr 2007
    Thanks Andrew,
    I just ordered one.
    fromMarty
    Jul 2007
    Where can you get the circuit to go inside the case?
    Would assume thru the normal sources but would be a complete key.
    Don't forget to check your key frequency.
