Results 1 to 10 of 12
Thread: 110 Wagon -> Ute Conversion.
    Mar 2012
    Humpty Doo - Darwin
    Hi all!
    I want to convert my '92 110 wagon to a Ute. Does anyone know if a Series model Roof will do it?
    Goots
    Caboolture
    No joy different over the windscreen. Series are flat across the top of the screen. Unless you want to replace your windscreen with a split series wind screen.
    Mar 2012
    Humpty Doo - Darwin
    Hmm ok then, but if I did replace the windscreen I'd be right hey? I presume this isn't advised and theres an easier way... Are those windscreen hard to come by? I guess I might ask that in a Series section!
    Goots
    in the wild New England, NSW
    the most straightforward method would be to use a 110 ute roof and rear window panel, and rear lower panel, although a series rear window panel (with the door stop recesses) would do...
    you could probably use a series ute roof with a series windscreen - but you could have some fun rearranging the wipers
    I'd think it best to keep the 110 windscreen and get a 110 ute cab roof - they are around
    your existing "B" pillars won't be of much use - both the series and the 110 ute door stop recess (in effect replacing the "B" pillar) is comprised of the fronts of both the upper and lower ute rear panels...
    (sell your 110 "B" pillars & rear doors to me to offset your costs )
    and where is your fuel tank filler ? - a series ute rear lower panel will have a fuel filler hole on the driver's side whereas a 110 won't
    if yours was a hard top I would swap with you
    preston
    I've done the reverse
    The two rear panels are easy to find on eBay (ATM)
    The roof is rare and expensive
    Hobo (?) in Adelaide has fiberglass replacements but I'm not sure how much work they need
    Use defender pillars as county are different
    (striker location)
    Ever considered hcpu or full body ute?
    They look the goods
    I used to have a tray andneeded
    to tub it for 255/85/16 tyres to fully articulate or
    the tray was going to be way to high and lift the
    COG unreasonably
    I would consider a extra cab telstra style as well
    Just chop a full length roof down
    Dc
    Mar 2012
    Humpty Doo - Darwin
    Ok,
    Its my brothers 110, 2 door so sorry I cant sell the back doors! He wants to cut it down and i got alotta series utes here so was wondering it it'd work.
    Just in research stages then we'll start getting the gear together, would the dual cab chop be easier? I suppose a DC chop might be pointless if he doesnt already have back seats.
    Goots
    PS whats HPCU/Full body ute?
    Mar 2012
    Humpty Doo - Darwin
    Quote Originally Posted by uninformed View Post
    http://a7.sphotos.ak.fbcdn.net/hphot...06789483_n.jpg
    Thats the vehicle in question. My bro is Interested in a swap.
    Darwin to GC bit of an issue. Plus I cant have the down time atm. But yes that is what Im after......
    Mar 2012
    Humpty Doo - Darwin
    Oh ok, its my bros, hes in ACT At the moment, well the car is hes at Townsville for some AJ training(just this week). Hes in no rush I'll let him know and keep in touch with you if you like?
    Goots
