Results 1 to 10 of 19
Thread: Petrol guage going crazy
    Oct 2010
    Carindale, Brisbane, Qld
    My fuel/petrol guage in my 2000 4.6 has started acting up. It has been fine for the last 18 months. Now it shows low when full or high when empty, or middle when either. There is no rhyme or reason to it.
    Should I suspect the sender or the guage?
    Where is the sender?
    Anyone know a good way to test both?
    Thanks!
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Hi Glen
    the sender is usually the problem. It's attached to the pump. It can get "gunk" on it which plays up with the variable resistor... hence unpredictable readings on the gauge.
    I had this problem a couple of years ago... as a quick fix, I put a couple of cans of fuel injection cleaner in the tank on a long trip (BNE-SYD) and it eventually cleared... maybe worth a try
    PS: Do you have a Faultmate? If so, you can test the gauge: In the BECM mode (IIRC) Faultmate allows you to "force" the gauge to "full" and "empty" ..
    Coogee, South of Fremantle, WA
    I had a problem just after I got the car. Ran out of fuel when the gauge read 1/4. As Hoges did I took advice on using Injector cleaner in the fuel and no more issues. I dont think its that uncommon if you do a bit of searching. I must admit I lost faith then and its never completely returned, I never let the tank get lower than 1/4 without reserves at hand.
    Fuel gauge fault ?????
    Poland (I kid you not)
    Mine does the same. It happened before the fuel-pump conked out on me, so I've had the fuel sender out. I tried to clean mine up, but I think it just physically wears out. I can tell you it's not the petrol gauge as I swopped mine out for new oem green background gauges and the result is the same odd and the no reading at all.
    Btw, if you decide to remove the fuel pump to get at the sender, make sure you stir the tank up good and pump out all the fuel and have a new fuel filter as you'll stir a heap of dirt in the tank
    rhinoP38 Guest
    Smile
    Hi,
    I had the same issue with my beast and I kept running out of fuel.
    I ended up taking the fuel tank out and removing the variable resistor (fuel sender) and cleaning it by hand with some WD40. I also bent the prongs for the sender contacts in a bit so they made good contact with the potentiometer.
    Seems to work fine now, although Im cautious about letting it get too empty.
    Quote Originally Posted by rhinoP38 View Post
    Hi,
    I tried that too and made mine worse
    Aug 2010
    Pakenham
    I found that E10 can have an adverse effect on the fuel sender also. Don't use E10 anymore due to that reason plus more.
    There was a TSB issued a few years ago on exactly that point warning not to use ethanol blends as they cause problems with the resistance of the sender unit...
    Jul 2010
    Sydney/Balmain
    Quote Originally Posted by redandy3575 View Post
    I have been using plus ulp from united for 12 years cant say i have had an issue with my fuel guage. Infact i am continually amazed how accurate it is. I routinely guess by the guage what i will put in to fill the tank.
