Thread: Air bags
    Mar 2007
    Seaford, Near Franganistan, Victoria
    Air bags
    G'day all,
    A quick question. Can the SRS airbag system be legally disabled on a 96 Disco?
    Why? I want to modify the vehicle.
    St Helena,Melbourne
    4.28 MB
    This has been discussed before and i 'm pretty sure that since it was an option and not standard you are legally allowed to disable or remove it, a search should bring up conclusive evidence.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Somewhere else, QLD
    x2 what he said - it was a reasonably interesting discussion.
    As to actually doing it - with battery disconnected, it's relatively easy. Find yourself a non SRS steering wheel, and operate on the dash to remove the little bulbs that illuminate the SRS warning light and fit a grab handle. You'll still have a hole in the passenger side dash, but it's not too bad. You also need to fabricate or find a non SRS horn connector. Also remove the SRS warning stickers so you don't have problems during inspections.
    Mar 2007
    Thanks, I'm currently searching but not having much luck with specifics.
    I would've thought that it would need to be engineered?
    Oct 2011
    North West Vic
    i was told here in qld it is not legal however on models that it was a option on it can be removed and you can get away with however you are not allosed to remove safety devices.
    check the adr for the final word
