Hi Gerald
Drives me nuts when that canary sings.
My latest thoughts are that the pulleys are a minuscule out of alignment.
Holding a long steel ruler as a straight edge against the harmonic balancer, using a verier caliper measure from the edge of the straight edge to the first ridge of where the multivee belt run then go around each of the other pulleys in turn and repeat the measurement.
You may find that one of the pulley's needs a shim making, to get the pulleys mutlivee ridge's back in line.
Carefully clean out the gulley's of the multivee's with a thorough action, that will stop the belt climbing to one side as well.
The axis of the shaft for the alternator may not be parallel to the crankshaft axis, a bit of fiddling is needed to fix that error!
