Thread: GPS and Wireless Reversing Camera
    Mar 2007
    Tarneit VIC
    I am looking at getting a reversing camera for my D2 and I found this
    7" CAR GPS NAVIGATION SYSTEM wireless Reverse Camera 2012 AUS 3D MAP 4GB 128MB | eBay
    Anyone has experience with this type of device?
    How good the wireless reversing camera?
    How good is the GPS and will I be able to load ozexplorer map into it?
    TIA
    d@rk51d3 Guest
    Watching with interest. I've been eyeing them off myself. Want something in the Santa Fe.
    I have a wireless system for my 101 - tested but not fitted - likewise my brother bought one for his Triton - neither has the transmitting power to transmit through the metal work of a normal vehicle with a reliable signal. My brother got rid of his and bought a wired one. In my 101 if I lift the transmitter above the bodywork it works OK but from a lower down position the signal is not strong enough.
    So I would ensure that the signal will be strong enough to transmit to the reciever from its mounting position.
    Oct 2007
    wetherill park
    I have the version before that no FM radio but it works well just dont lose the stylus camera works in a series 3 no proplem but its a canvas top and yes you can use ozi ce
    Wireless cameras state that you should not fit to cars with a chassis as there is too much metal.
    I tried to fit one to the 110 and did not work at all. I now just buy the cable ones of eBay
    Due to having two young boys I have them on all my cars. Cost about $60 and easy to fit
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by Reads90 View Post
    Do you mean extension cable for transmitter?
    If I can get that one would be great. I guess it is easier to put the transmitter inside the car than if I have to run cable from camera to monitor
    Quote Originally Posted by dearot View Post
    No - the system is a wired system not a radio system - I would definitely recommend going to a wired system.
