Results 1 to 6 of 6
Thread: Td5 making black smoke
    Mar 2010
    Patagonia
    A mates Td5 Defender (2006) is making lots of intermittent black smoke.
    New fuel pump, new FPR, new injector o-rings & washers. New turbo hoses. Boost pressure as well as other fueling parameters all in good order.
    No oil consumption. No significant blow-by. Installed known good injectors then known good ECU, all to no avail. Does it either when cold or warm. Sometimes idles ok, other times smokes right from start up, no clear pattern here. When floored for a while it starts burning clean. Intake manifold and intercooler look clean.
    Heavy smoking while idling is usually accompanied by abnormally high cylinder corrections (live cylinder readings jump from +/- 2 to +/- 24) and somewhat rough running (not rough as when running on 4 cylinders, just not smooth). No oil in harness, red plug or ECU. No misfiring whatsoever.
    At my wits end... any ideas?
    Thinking porous head but may very well be loosing it...
    in no particular order
    partially blocked intercooler
    collapsing air filter
    turbo failing
    contamination on the crank angle sensor or the flywheel drillings
    bad earth
    harness damage
    alternator fritzing.
    MAF/MAP or ambient air sensor not ranging correctly
    Mar 2010
    Patagonia
    Thanks & will keep you posted!
    Melrose SA
    So Mturri what was the problem??
    outnabout Guest
    Black smoke
    Hey fellas,
    Similar problem with my 130 (2003). Decided to start blowing black smoke after a Tassie to Qld trip in the late December heat.
    I'm a light weight when it comes to diesel mechanics and just carry out basic maintenance and keep a close eye on basic operating trends.
    How helpful are the diagnostic computers in determining the cause of these sorts of problems?
    On another note, the handbrake lever was bloody hot during the trip. I did take it easy to manage the heat but was pretty concerned. The engine temp gauge was pretty constant throughout so I was guessing gearbox/transfer box radiant heat (didn't seem to me that the exhaust was the cause).
    I'll have to take it in to the grown-ups for an educated eye to have a look at the poor old girl I think.
    Mainly just posted this to stop getting kicked off this brilliant website.
    Cheers Fellas
    Jan 2012
    Now in Sunny Perth
    Oldie but goodie but have you changed the injector harness?
