Results 1 to 6 of 6
Thread: D2a Original Body Height
    Oct 2011
    Fremantle WA
    Anyone happen to know the "as new" D2a measurements from ground to under the top of the front and rear wheel arches or some similar measurement please? I'm trying to determine how high the body should originally have been before I start playing.
    I vaguely remember some comment/s quite a while ago, but now can't find any reference. Cheers Gavin
    99.87 MB
    Quote Originally Posted by gavinwibrow View Post
    It varies between cars and there is a range of standard heights but:
    Typical measured standard hub to guard heights are:
    Front 475mm
    Rear coil 470mm, and IIRC SLS was a little different.
    All but 1 measured example sat at the lowest specified ride height from RAVE when new or newish.
    RAVE Specifications:
    Front 500mm +/-15
    Rear coil 483 +/-15
    Rear SLS 473 +/-15
    Slunnie
    Douglas Park, NSW
    Isn't there a height measurement on one of the interior sunvisors?
    It's there for underground carpark heights & the like.
    99.87 MB
    Even those are incorrect generally. I think it had 1980mm to the top of the rails, where mine never came to that height until I put a 2" lift into it.
    Slunnie
    Oct 2011
    Fremantle WA
    Front 475mm
    Front 500mm +/-15
    Rear coil 483 +/-15
    Rear SLS 473 +/-15
    Thanks Slunnie - I must need new glasses - missed that in RAVE!
    99.87 MB
    No probs. Its in the general data section rather than the mechanical section.
    Slunnie
