If you have a Llams kit fitted you should remove its loom first and if the fault no longer occurs then look here http://www.aulro.com/afvb/1657476-post94.html about having the loom fixed. However a fault only when lowering to access height doesn't sound like a Llams connector problem.
					 . It is fixable but i wouldn't ask for it myself.
