Hi Flagg. If the batteries are sealed there is no gas build up as all the gasses are held inside the cases. Jim
Ive got two sealed lead acid batteries in my underseat battery box, all the gromits have perished and several large holes have been made for other wires in and out, on both the road and cabin side.
This is a significant source of noise, and im tempted to seal the whole thing up.. But, will this cause gas build up problems?
Jim VK2MAD
'17 Isuzu D-Max
I wouldnt seal it completely...
Lining it with acoustic material would do a lot to attenuate the noise
The battery compartment should not be sealed as there will be changes in pressure with temperature, and even if the battery is theoretically sealed, it may still gas in the event of overcharging or some other faults.
But it would be acceptable to seal it and provide a breather, preferably high level like the diff and gearbox ones.
The other option is, (when necessary) replace the batteries with sealed but vented types such as those fitted to Mercs and BMWs where the battery is under the back seat. They have an outlet at each end with a small tube that can be run to an external point but will not allow wet leaks on angles or overturning. One way to relocate a battery to the vehicles boot and not necessarily need engineering.
Hydrogen is lighter than air
Kinda related, my brother whilst checking connections at night with a lighter had a battery explode! Pretty amazing considering the ratio to oxygen it has to be
Also they smeared a fella inside a generator at hazelwood years ago, instead of removing the generator end bells they made man holes, till old mate dropped his big Jim torch in there, boom!
Leave it vented.
M
So long as you only run sealed batteries you can seal the battery box.
Having said that, I'd make sure it's not 100% sealed because then internal temperature build up will become a problem for the batteries.
Sent using Forum Runner
Regards,
Jon
