Results 1 to 8 of 8
Thread: HELP!! Computer run amok
    Sussex Inlet. N.S.W.
    My Toshiba Satelite laptop shut down in standby mode with the on off switch slowly flashing. I don't know how to wake it up. I have tried all I know but it just sits there defying me. Help!!!
    Jim VK2MAD
    '17 Isuzu D-Max
    it may need to have the battery removed and the power unplugged.
    Hold the power button in for 30 seconds and it should go into force shutdown.
    St Helena,Melbourne
    4.28 MB
    Usually just holding the power button down for while will cause it to shutdown completely.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Crafers West South Australia
    Quote Originally Posted by jx2mad View Post
    My toshiba satellite laptop does that when the battery is flat. Try plugging it in to the charger!
    thats a windows problem...
    from memory...
    if you're low on battery, and you put it in standby and the battery % drops below the % set for the thing to go to hybernate or save to drive and shutdown mode while its going into standby it will stay in standby until the battery goes completely flat and not put it into charge mode until the battery is completely flat.
    My solution was to set the standby battery percentage to below the hibernate or save to drive and shutdown battery %.
    Jan 2008
    Ireland
    Mine is doing the exact same and it makes no difference whether the battery is in or out it takes an hour to reboot no matter what I do..............
    Laptop having a Reggie
    My wifes laptop has gone nuts since we ok'ed a windows security upgrade!!!
    We can't use it anymore.
    South East Tasmania
    Quote Originally Posted by wrinklearthur View Post
    Linux will be the answer for those that have the guts full with Wiundows.
    I still using XP and as a conservative old bugger I do not think that I will upgrade in a harry.
    XP it is powerful enough to stirring the pot in the Soapbox section
