Results 1 to 10 of 14
Thread: Tail gate release
    May 2011
    Orange Grove WA
    Tail gate release
    My bottom tail gate on my D4 now requires two presses of the rubber switch to make it release.....is this the early stages on the mechanism failing ?
    Heading to Shark Bay in the morning.....need to be able to grab a coldie on arrival.
    Brett.....
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by discotwinturbo View Post
    Brett.....
    Brett
    That's why you need to get the front seat chiller box! You can grab the coldie before you arrive.
    Diana
    Dec 2011
    Forrestfield WA
    The car will cover the distance so easily and comfortably that you won't need a coldie when you arrive!
    May 2011
    Orange Grove WA
    Quote Originally Posted by BobD
    I am sure it will. Was actually tossing up between taking my touareg or the disco. Disco won due to long range tank and full size spare. Vw is quicker, and uses about 10% less fuel. Disco also has rear entertainment for the kiddies.
    Heading off at 4am....hopefully not too many roos around as I don't want to yet put a scratch on my bar.
    Apologies for all those on the colder areas.
    Will be feeding on some blue bone tomorrow night.
    Brett.....
    Oct 2006
    NSW Riverina
    Dilemmas dilemmas...
    Thankfully I haven't had this issue & don't want to either. I should read up on the mechanical over-ride before it does break. And while I'm there throw in a better sub too!!
    Dec 2009
    Mine was doing the same - got the tailgate adjusted by the dealer under warranty at the last service and no more problems.
    We found that in our case if you apply some inwards pressure to the lower tailgate before/when pressing the release button it would release on the first press.
    We did this for a couple of months before the fix and it and took a while for us to stop being surprised that it would release first go after the fix.
    May 2010
    Northern Beaches, Sydney
    The part that usually fails is the cable on the release mechanism for the upper section of the tailgate (the mechanism is actually located in the lower section though, and is separate from the lower section release mechanism).
    The one in my D3 died after a few years. I think it is too early for it to be failing in your D4. Hopefully LR has improved the design of the cable in the D4, seeing it was a common problem in the past.
    BONZER Guest
    Hi Brett,
    Just had a modified release fitted last week on my D3. Suffered the same two presses on the rubber for 18 months but realised if it failed with drawers fitted It would be hell to rectify. Enjoy your trip but get it attended to when you get back. Its easier to do whilst its still operational. Part was $66.
    May 2011
    Orange Grove WA
    Quote Originally Posted by BONZER
    Hi Brett,
    Thanks John.
    Just got back....very quick trip. Car went super well.
    I ended up leaving the tail gate opened while camping....started to take 3 times pressing to get it to open. Did not want to have no access to beer...and of course the food.
    Booked in for service tonight and for this to be fixed, taking into account what I have read here. I am sure they will say that they have never heard of this...the same thing they said about the economy being widely ambitious.
    Blue bone groper is such fun to catch....and sooooo nice to eat.
    Brett....
    Brisbane,some of the time.
    [QUOTE=d3syd;167644Hopefully LR has improved the design of the cable in the D4, seeing it was a common problem in the past.[/QUOTE]
    Does anywon know if it has been changed,improved?
    I want to put a cargo barrier in my D4,but a bit concerned about this issue.
    Earth to Sniegy................?
