If you have done that sort of job on other cars before you should find it a doddle.
 Brake pad replacement and discs
		I have the replace brake pads warning coming up on my D3 at 77,000. I'm ok with having to replace the pads but was wondering if it is something I could do myself or if it would have to go to a specialist/dealer?
If it is something I can do myself do I require any specialised tools or is it just multi grips, spanners and screwdrivers? Looking forward to any advice from anyone who has done this in the past.
Dom
 Fossicker
						Fossicker
						dominicbeirne,
Have a look at this link and it will tell you all you need to know about changing disc pads as well as all the tools that you will require.
DISCO3.CO.UK Photo Gallery - Bodsy's Brake Bible
Hope that this helps.
Lou...
can only recommend to only use the Landrover factory pad's my mechanic used same brand and specs after market pads and they squeaked for 2000k's until I got him to replace them with original Landrover and the squeaking went instantly
I have gotten 80,000 miles out of my aftermarket EBC rotors. I have changed the pads a few times, and lightly turned them at each new pad fitting. Compared to the 20,000 miles out of the OEM ones, there is not much comparison.
Pads are definitely a simple job to change... rotors should be easy enough to do also if you've done them before. Getting ready to change mine too so will be interested to hear how you go for prices.
Cheers Dom!
Hi Mully,
I have never done anything remotely as mechanical as this. Have done oil changes and minor maintenance on Unimogs in the Reserves but very different to working on the every day ride of my own.
I have downloaded the PDF from Disco 3 Club site, thanks Lou, so just trying to work out if I go for it or not. Will let you know next week if I do it or chicken out.
Dom
Hiya Dom, if you have any doubts definitely leave it to others as brakes (particularly on the heavy D3) are too important to not get 100% right.
Def have a read of that PDF and decide from there... any sincere doubt though and walk away for others to do... maybe ask if you can look over their shoulders.
All the best!
 Fossicker
						Fossicker
						I just checked out the PDF doco provided. Looks like a standard set of pads on both front and rear except for the sensor. If you have changed any pads before I would give it a go.
What's the worst that could happen!........
