Results 1 to 4 of 4
Thread: 2a power steering conversion
    grey boy Guest
    Question 2a power steering conversion
    Hi guys I am doing a ground up rebuild on a 1962 2a 109 flat tray ,I would like to convert it to power steering if possible.So I was hoping somebody would be able to tell me is it possible ,what parts I need to source to achieve it and this is the important question is it sacreledge to do it cheers Graeme
    Oct 2010
    I recently removed the power steering system from DeeDee - my S2a. It was a hydraulic ram type where the drag link has a valve arrangement fitting to control hydraulic fluid pressure into a ram connected between the drag link and the chassis. It's a fairly simple arrangement to instal but it limited the steering lock a bit much for my liking. It certainly worked well though.
    As to "is it sacrilege", I'd say it might be to some but if it makes the car usable and/or enjoyable for you and gets another S2a on the road, then it's easy enough to modify and then revert to standard if a future sale requires it to be standard. I still have the gear I removed just in case I decide to refit it. Given my current situation of having a broken hand with a cast on it, I wish I hadn't removed the power steering as I can't drive DeDee for a few weeks. With the power steering I could. (...and before anyone arcs up, yes I know you shouldn't be driving with a cast on a hand. My wife gives me enough grief without you lot starting up! ... ... )
    John B
    Irymple, Victoria, Australia
    There is a thread on here about fitting a Land Cruiser power steering assembly to a series vehicle.
    A lot of good photographs to go with it too!
    I think it was "Banjo" who posted the thread!
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    It can be done, as the above posts indicate, but regardless of the approach used, it is going to be relatively expensive and/or a lot of work. With steering gear in good nick and standard tyres, it is hardly necessary in most circumstances - the turning circle of lwb Series Landrovers is more of a problem and has no feasible solution.
    My view is that it is unlikely to be worth it - a better option would be to sell the Series vehicle and get a coil sprung Landrover, which mostly have power steering and to which it can easily be fitted.
