Results 1 to 8 of 8
Thread: What engine oil?? Urgent
    Toowoomba
    Hey all.
    Well Smokey be in a bad way so says my mates.....so I need to know if I go to servo what type of engine oil would I need??? A mate of mine ( who went nancy boy on me) once told me but I cannot remember....thanks in advance,
    Stevo
    May 2010
    melbourne
    Hope this helps it's out of rave
    in a pinch any 0/40 or 10/40 will do the job.
    synthetics better than mineral (generally)
    once you're out of the poo, change the oil and the filters so you're running a known single brand.
    Brisbane,some of the time.
    Must be 5w/30,fully synthetic.
    Any brand will do,but as above specs.
    Feb 2012
    Hoppers Crossing
    I use Mobil 1 fully syn 10/40. So far so good
    Toowoomba
    Thanks lads.....................ended up flat bedding Smokey to be on safe side. Looks like a possible massive leak crank shaft seal?? plus oil flicked everywhere so fanbelt starting to shred......so not charging alternator so wouldn't even start and also rear airbag rooted......happy birthday to me......not ,
    Stevo
    Nov 2007
    On the road.
    i had that with mine, the harmonic balancer ($950) died which also caused the seal behind it (camshaft) to start letting go and also destroyed a belt.
    fixed up and good as new again.
    Feb 2011
    Hobart, Tasmania, Australia
    For future reference, all the major oil companies have online lube guides freely accessable online. e.g. Penrite Oil Australia - NetLube
