Results 1 to 10 of 12
Thread: 2000 v 2004
    Harold Clark Guest
    2000 v 2004
    I have purched a 2000 td5 and have had a few probs. I am thinking of getting a 2004, does anyone have an opinion as to whether the 04 is a better model more reliable.
    regards
    North Central Victoria
    What sort of problems are you having? Is it a diesel or petrol? Manual or auto?
    I have a 2000 D2 and find it great. It is a 12 year old car though so some things will be going wrong and wearing out - I have the squeeking manifold rearing its head as we speak. Some people state that you should go for the later years of a model run. I think the early ones are fine if they are maintained properly. The plastic dowels of the early models in the head are a worry to some but I've had no problems. My mechanic thinks that if the dowels fail, there is something larger afoot anyway. But each to his own. So long as the car has been serviced properly and the problems can be fixed, I'd stick with the one you have over the one with the pretty headlights. That's the main difference as far as I can see!
    Perth WA 6149
    The 2003/4 models have a better reputation, but I would be inclined to stick with what you have unless the issues are terminal or you desire a newer car.
    Remember the youngest is going to be 8 years old now and all will have their issues. At least you know the history of yours and if you factor in change over costs, that will buy a lot of repairs/parts. Condition rather than year is all important wrt to reliability.
    I was in similar situation last year deciding whether to keep my soft dash classic or trade up to a disco2 TD5 after i had bought a caravan. At the end of the day I determined it made no sense economically. Pity about a wee electrical fire 3 months ago which wrote off the vehicle, so I am now looking for a TD5 D2a anyway.
    Steve
    Apr 2010
    Adelaide, southern foothills
    Go the 2004 D2a
    From what I can gather, the 2004 Classic would be the one to get. They're coming down in price as they get older and they seem to have most of the bugs ironed out and be good value as far as standard equipment goes (DVD player etc).
    I have an early built MY2003 D2a (9/02) and have had a few of the early D2 problems (FPR, fuel pump, front shaft, amigoes, fuel cooler o-rings) so I reckon MY2003 must sit half way between 2000 and 2004 models as far as reliability goes! I agree that its usually best to get the last of the model run as most of the issues are sorted by then.
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by Davetd5 View Post
    With the exception of the change from plastic to steel head dowels there should be little difference in reliability of the Td5 engine between pre and post-facelift d2s. Fuel coolers, fuel pumps, fpr are the same design and suffer from the same issues. The primary advantage of the 03/04 vehicles in this regard is that they are younger. Once they hit the same age/mileage as the 2000's you'd expect them to experience the same kind of issues, and that is borne out by forum posts.
    The majority of the "fixes" for the 03/04 are relatively small but worthwhile improvements. Off the top of my head these include:
    - Revised rear diff breather (in the 02 as well)
    - Revised SLABS ECU with improved TC/ABS programs and improved tolerance of low sensor output
    - Revised brake master cylinder and callipers for better brake feel
    - Revised front hub carrier (altered camber)
    - Revised ACE ECU
    - Revised spring/shock rates
    - Revised suspension geometry
    - Revised transfer case design to reduce operating noise
    - User operated diff lock
    - New front propshaft design on Td5 Auto models to reduce noise/vibration transmission
    Ultimately the 2004 D2a is the most refined of the D2 series because of these kinds of changes and incremental improvements, but they don't make it immune from the problems that afflict the earlier D2's.
    Paul
    Jul 2010
    Quote Originally Posted by OffTrack View Post
    - Revised ACE ECU
    Paul
    Not to mention the larger intercooler then earlier models and revised fuelling map on the ECU that made it a far easier car for towing or general driving.............
    Harold Clark Guest
    Quote Originally Posted by gusthedog View Post
    The torque converter cracked also developed a rad leak
    Quote Originally Posted by Harold Clark View Post
    Get an ashcrofts torque converter - JC from tassie raves about them in D2's. And radiators eventually wear out, particularly the plastic buggers in D2's. Both of those could happen in a later car too. At least you know what $ you're up for with your own vehicle. If you buy another D2 - even a later model - you could be up for some hidden repairs anyway.
    Recycling at work - keep the ol girl going with a few repairs I reckon
    Toowoomba
    I think this will answer all your queries and boo hoo bugger orf D2 owners
    http://www.aulro.com/afvb/discovery-...a-section.html
    regards
    Stevo
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by stevo68 View Post
    regards
    Stevo
    It's filled with useful information like what oil to use when your mates tell you your d2a needs some oil...
    Well Smokey be in a bad way so says my mates.....so I need to know if I go to servo what type of engine oil would I need??? A mate of mine ( who went nancy boy on me) once told me but I cannot remember....thanks in advance,
