Hmmm,
From your description there it does sound more like a transfer case/gears issue than the main gearbox as I don't recall ever hearing of significant grinding noises from a failed gearbox. I did hear of troubles with misaligned flange plates creating similar issues for the transfer case (loss of drive) when the gearbox had been removed and reinstalled. Others more knowledgeable than I may be able to assist here.
It's all very well to change the transmission fluid at regular intervals but just how much swarf was lying in the sump and/or in the filter when it was drained? The more of that there is, the more likely failure is. I know preaching to the choir there.
Good luck with it. I'll add my support on the transfer case side of things.
Over to the more experienced.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
