Results 1 to 10 of 23
Thread: No Heater
    Nov 2011
    No Heater
    Hi Guys can any one help on where I start to look, I have no heater the air con works fine the heater has a very very light warmth to it but only out of drivers side the pasenger same as outside temp, book simbal ! is on temp screen have tryed every diffrent setting 98 HSE
    Zuk
    Jul 2009
    Mid North Coast, NSW
    287.34 MB
    what youll prob find is its a problem with the heater blower motor, and there is one fan for the ac and one for the heater.
    it could be a faulty switch, relay, fuse, resistor pack, or motor.
    for me in my older d1 (92) it was a siezed motor.
    good luck, grab a multimeter and wrokshop manual and start tracing the volts...
    Nov 2011
    Hi Haydent is the blower the same as the fan control because the fan works fine just blows cold air.
    Both sides? One side? Is there any air blowing?
    The car has two blowers, one for each side. It's unlikely both would fail. What happens when you use the temp control buttons to go from min to max on each side? Do both change? Neither? Only one side? If so, perhaps it's the blend motor(s).
    My first guess would be a blend motor. Read the diagnosis pages and repair pages on RANGEROVERS.NET HOME e.g., Blend Motor Diagnosis and Replacement
    Jul 2009
    287.34 MB
    sounds like a problem with your mixer if your fan works with the heater settings on
    Nov 2011
    Thanks Guys the temp display works fine both sides up and down the fan works fine, when auto is on the fan switchs to all vents, you can turn the air on and off all direction buttons work if you switch to face vents and put your hand on the center you can feel a small amout of warmth out of drives side but dead cold out of pasenger side nomatter what fan setting you have it on.
    Zuk
    Quote Originally Posted by zuk View Post
    Zuk
    When you adjust the driver's side temp up and down, does the temp of the air change? That's why I asked you to go from max to min.
    If so, you have a faulty blend flap servo motor on the passenger side. Quite common.
    Read the diagnostic procedure in the link I gave you for RangeRovers.net
    Nov 2011
    No the temp of the air dosent change at all, display temp go's up and down fine.
    Blend motor failure
    Similar issue and Faultmate said blend motor and feedback capacitor failure.
    This morning temp outside was about 10 degC ...turned on ignition and voilĂ ...no book symbol and I hear blend flaps moving...everything working as it should ...until ambient temp got above 19-20 deg C...
    May need to insert larger self tapping screws in casing....
