Results 1 to 10 of 18
Thread: Bilstein Rear Shock Absorber Stone Guards
    Feb 2011
    Hobart, Tasmania, Australia
    Question Bilstein Rear Shock Absorber Stone Guards
    Are the Bilstein Rear Shock Absorber Stone Guards from Suspension Stuff ( Discovery Series 2 Bilstein Shock Stone Guards, Suspension Stuff ) worth it?
    99.87 MB
    They look the same as the ones fro Bilstein. I run these and they're pretty good. The only thing is that I run 2 per side to get better protection.
    Slunnie
    Coogee NSW
    Guards are a must have to protect the mono tube from stone damage off road.
    Feb 2011
    No guards on the front I assume because the spring surrounds it?
    Avoca Beach
    I made some with perforated steel from Bunnings at a total cost of say $10.
    There is a brand of perforated steel with diamond shaped holes that comes in angles corners etc and flat bits.
    Looking at my shocks which have done about 30KK on dirt, 99% of the stone strikes are in the lowest 60CM.
    So I bent 2 lots of straight bits and stood them off the shocks so that the airflow would not be disrupted.
    If I get motivated I will get a photo, but I do not really agree with the commercial guards as I reckon they will inhibit cooling.
    BTW , I was in two minds about even fitting the guards as I think the danger is highly overrated.
    Could anyone advise if they have had Bilstiens actually fail because of dents or is it an urban myth?
    Regards Philip A
    Dec 2011
    sydney - pining for the western desert
    never run Billies, but i once dented an OME shock about 7mm inward & it continued to work fine (lifted series 3 shortie).
    99.87 MB
    The bilstein bodies are really thick for a shock, you'd be pretty unlucky to dent it. Other shocks have twin or more shells which are made from lighter material which is why the dent so easily and then keep working.
    Slunnie
    Central Queensland
    what about nolathane #49112?
    Nolathane 49112 Shock Absorber - Stone Guard
    Jan 2011
    PhillipA -
    I'd appreciate a photo as I have just bought a set of Bilsteins and plan to fit them shortly. I'm heading for a few thousand kms of off road and want stone guards. I'd thought about making my own.
    Avoca Beach
    OK tomorrow.( although it is my 43rd wedding anniversary and it might be vetoed.)
    Regards Philip A
