Results 1 to 9 of 9
Thread: 1 for the TV guru's
    Ean Austral Guest
    1 for the TV guru's
    Gday All,
    My TV has a strange problem and this is what it is. All channels work well in digital but the ABC ( all channnels ) have no volume. If I put the TV into ATV they all have volume.
    The TV in our daughters room works fine on DTV with all ABC channels having volume.Both TV's use the same antenna, and picture is fine.
    Can anyone enlighten me how this can happen, or what they think could be the problem.
    Cheers and Thanks
    Ean
    Toowoomba
    is the set top box muted?
    Check your the TV setup menu, sounds like you have a 'mute' setting switched on.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Ean Austral Guest
    Quote Originally Posted by waz View Post
    Is it possible to mute just 1 channel..ABC I think has 4 seperate channels and none of them have volume , but every other 1 does, even SBS.
    Cheers Ean
    Two Rocks WA
    Ean Ring the manufacturer of the tv and ask if there has been any firmware updates for your model.
    There have been and will be movements of channels and frequencies at various times and mostly there is a fix via the manuafacturer of the tv.
    There was a forum that advised of these issuies but I cant remember exactly which one.
    That is where I would start. I cant see why the sound would not be there only on the abc.
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Williams West Aust
    Ean.
    Try pressing auto tune,may help.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Ean Austral Guest
    Well, I ran the TV thru the auto tune as LandyAndy suggested and the 1st time all channels except 7 had volume, done it again and all is working well.... must be some gremlins living in the TV..
    Thanks All
    Cheers Ean
    Feb 2012
    Parkdale, Melbourne
    x2 for firmware upgrade if you're having buggy issues like that.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    richard4u2 Guest
    sounds like the tv's go tropo as well
