Results 1 to 10 of 37
Thread: Got Wood ?
    Mar 2009
    Port Stephens N.S.W
    Got Wood ?
    I do ...
    ... and it's a thing of beauty !
    ... 'cause "My Shaft's A Woody!"
    When I got home I told Mrs F I had a new fully greasable shaft ..... she didn't seem too impressed that Daddy's got a Woody
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Feb 2012
    Hoppers Crossing
    Im getting wood...
    Hopefully sooner rather than later...
    Geelong, VIC
    I've had Wood for a while (and very happy with it).
    Mine looks the same as yours, but is probably shorter
    Steve
    Jul 2011
    Adelaide
    I got wood today. Can't wait to put it in.
    Mar 2009
    Port Stephens N.S.W
    Its almost in ...
    With Belanglo boys night next weekend, and the Cross Border Gathering the following week I figured it would be a good time to get the TW shaft fitted.
    Talk about a bitch to get the standard shaft out. When I bought the D2 one of the uni's was replaced before we picked it up (was flogged). The one at the diff end of the DC was changed (it has a grease nipple). The T/Case end uni & the diff end uni are still original ... 164,000km and no play. The new one that was replaced is fine, BUT, the play in the centre bearing was pretty noticeable ... latley, I can hear it rattling at slow speed and on over-run I will admit to it being a known issue for the last 40,000km, with regular checks, and monitoring it as it got progressivley worse (and it never got hot. I checked that constantly) ... and when the DC is bent to full angle the ball still has grease on/around it, BUT, the centre pins are obviously badly worn .... time to withdraw from the 40k lottery
    Whose the goose who put super strength lock-tite on the propshaft nuts & bolts when they re-installed it!! ?? Duh !! The T/Case end was a bitch, and the diff end was 10x worse ... and 14mm spanners and sockets don't quite cut the mustard, but it's out, with plenty of expletives! Have to get new bolts & nuts ordered tomorrow as the old ones are totally ****ed!
    Here's a few pic's of the old vs new ... notice how much more angle the Tom Woods shaft has compared to the standard shaft ?
    New nuts & bolts in a couple of days and we're good to go.
    Kev..
    2008 Isuzu D-Max
    Jul 2011
    Adelaide
    Only took you 4 months to fit it
    Hey Kev
    I hope you got the tool to grease the centre of the Cardan joint?
    I got one when I got my shaft .
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    NSW far north coast
    Been meaning to fax my order w/dimensions for the Deefer off for the last week.
    Will ring and fax Tues. morning.
    Found spline wear on the Patrol front shaft too t/night
    Might send that one to Gibsons for a refresh.
    Can't wait to say I have a fully greaseable Woody too.
    Goes with my Big Horn/s
    Mar 2009
    Port Stephens N.S.W
    Quote Originally Posted by Rocky88 View Post
    I was taught never to rush a good thing ... All good things come to those who wait
    ... And besides, it's not back in yet !!!
    Sent from my iPad using Braille
    Kev..
    2008 Isuzu D-Max
    Mar 2009
    Port Stephens N.S.W
    Quote Originally Posted by LowRanger View Post
    Hey Kev
    Yes Wayne, I sure did ... However, a needle nose grease gun like we use for greasing chainsaw bar sprocket noses works just as well.
    The "tool" I was sent was a plastic conical tit with a female thread in one end ... I have nothing it will fit too .... I think my needle nose grease gun will work just fine.
    Kev..
    2008 Isuzu D-Max
