Results 1 to 8 of 8
Thread: Dumb iron massage
    Dec 2010
    Kiewa Valley, VIC
    Dumb iron massage
    The lhs dumb iron has taken some significant impact (see bumper thread) in the past and now comes time to fix. The dumb iron has been bent inward about one inch. There is a crease in the chassis either side just forward on the front cross member and a slight buckle on top and bottom.
    I was thinking a jack and big hammer (BIG) may coerce the dumb iron back into position...... Is there a better way?
    Again, I am curious to know if I apply heat to the metal, will this help?? Guard and radiator obviously to be removed.
    Many thanks,
    East-South-East Girt-By-Sea
    1.20 MB
    You could try a port-a-power and jack it back.
    The best results will be obtained by splitting the welds along the seams, then re-align the dumb iron in all 4 directions and weld back up. Remember with any deformation of the chassis there will be stretching of the metal so the seams wont fully align in quite the same relationship as they did originally.
    If the chassis has had a shunt like that, it would be worthwhile checking the alignment of the entire chassis. There is a diagramme in the workshop manual.
    Particularly check for ripples in the LHS rail just in front of the first outrigger.
    Narrogin WA
    Good advice from Diana!
    Try and determine from which direction the initial force which did the damage came from, and then you will need to pull or push in the opposite direction to stretch it back.
    In addition you may need to anchor the car to the floor, or a post, to keep it still whilst the pulling/pushing is done. Heat will be OK, but you may need at least two oxy torches going and a couple of helpers. Remember that the metal is only 2mm thick so you don't want holes burnt! Measuring where the front spring hanger eye ends up, is critical for good steering and handling.
    If there is any rust in the bent bit, it makes more sense to make a new part and weld it on,
    Cheers Charlie
    Cheers Charlie
    Northern Midlands, Tasmania
    How is a port-a-power used?
    Must the chassis be secured down then pushed from below to straighten in?
    WA
    Quote Originally Posted by korg20000bc View Post
    You want to pull from the front / push horizontal, as the force would have been applied that way when it ran into something.
    Proper chassis aligners run under the vehicle and anchor to the rear axle or chassis.
    You will need >>20T force to fix that!
    Cutting and rewelding, as Diana suggests will be much easier.
    Dec 2010
    Kiewa Valley, VIC
    I had another long hard look at it this morning and I have decided (in concert with Diana's input) to cut the seams and work it that way. I have also decided to cut about a 4 inch section out that is bent inwards and replace, as it would impossible to bend it 'outwards' I think.
    Thanks for all the input, will let you know how it turns out (pardon the pun).
    Nov 2006
    cardiff ,NEWCASTLE.
    On mine when i got it they were so rust & colapst i cut them both off & welded new ones on , you could do that to..
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    WA
    Quote Originally Posted by Mustlust View Post
    I was once driving along offroad in a IIA and ran into a stump that was in the middle of a track hidden by a small clump of lantana. The dumb iron bent similar to yours.
    Fortunately my neighbour at the time had a chassis stretcher. It took ~35T + strategic cuts to pull it out.
