Its not being off the tarmac per se that is the problem
Its driving in the dust of other vehicles. You can't avoid that if you are in a convoy, The occasional dust from an oncoming vehicle is fine,
a footy sock won't do anything to help
I use a Landcruiser snorkel head , (ebay 'mushroom snorkel head' $45) they are good for the 4.5 V8 Turbo diesel so breath plenty good enough for a Defender
As in a Donaldson pre cleaner the air spins up & the dust goes to the outside by centrifical action , in a donaldson it spins into a bowl (more efficient) but in the Toyota head it exits thru two slots in the top, (don't seal the slots up)
It is also designed to expel water so you wont get the mud in your snorkel.
Also Nanocom airflow tests show no difference compared to a Safari Ram head - just can't figure out why I never seen any other Defenders with them ???
http://goingbush.com/landy/lchead.jpg
