Results 1 to 10 of 18
Thread: Are the cabin 12v sockets ignition controlled?
    Mar 2011
    Cairns
    Hi,
    I'm curious if the 12v outlets beside the gear stick are always on, or ignition controlled?
    I've recently installed my UHF and as a temp power feed I'm using one, but I have noticed the radio stays on after I turn the engine off.
    Any advice?
    They are ignition controlled & will time out after 2-3mins from memory.
    Sent from my iPad using Forum Runner
    Feb 2010
    Mount Martha
    I have wired the drivers side front 12V socket & the one behind the centre console directly to the second battery. This way, I can keep phones etc on charge and not worry about the charger going off once the igiontion has timed out.
    Same with the rear socket in the back of the wagon.
    Cheers, Craig
    NSW SW Slopes
    I replaced the relay in the cabin fuse box with a link to provide permanent power to all aux power sockets except the driver's side front console which doesn't exist on mine now anyway.
    Bangor, NSW
    I think the answer will depend on what car the OP was referring to!
    IIRC, the D3 was ignition controlled power socket. Whereas my D4 has two power sockets - the one on the passenger side is also ignition controlled. However the driver side one on the D4 is timed for 2 mins after ignition is turned off, and comes on when a door is opened - for another 2 minutes. I learned this the hard way - trying to charge an iPhone when camping after I got my D4 - before I had installed permanent power to the luggage space. Imagine the joy of opening the door every two minutes to charge a phone!
    Mar 2011
    Cairns
    Quote Originally Posted by Disco4SE View Post
    Cheers, Craig
    That's useful Craig, how did you get to it. I'd like to wire up my UHF to one of them and have only just started to ponder how I get in there. D4.
    cheers,
    Feb 2010
    Mount Martha
    Quote Originally Posted by Ozzy119 View Post
    cheers,
    Ahh, I know I sound really clever, but it was my auto electrician that did it whilst doing the second battery etc
    Cheers, Craig
    Bangor, NSW
    cheers,
    Instead of tapping into the power socket source, why not just crimp a male spade connector onto your power lead and plug it into one of the spare spots on the fuse board? It sits behind the lower glove box, near the bottom of the fuse board.
    Mar 2011
    Cairns
    Quote Originally Posted by jonesy63 View Post
    Hi Jonesy63,
    I was hoping to avoid any more hassles with getting wires through the firewall. I already have coax aerial, Traxide 12v to rear and P3 brake controller so I'm pretty full on the 2 available holes. Aside from which it's a total arse getting cables through them.
    With the power source already in place I woud like to just tap into it. At the moment I have a simple connection using the smokes plug.
    Bangor, NSW
    Ozzy - re-read my post... the fuse board is behind the lower glovebox. Take your existing power lead for your UHF, crimp a male spade connector on the end - and plug it into the spare power socket in the fuse board. It is already in the cabin - behind the glove box - no need to run power through the firewall.
