Thread: td6 message
    Feb 2009
    Bondi
    td6 message
    Good day to you all
    Started my TD-6 HSE up today and the messages DSC INNACTIVE and AIR SUSPENTION INNACTIVE came up.
    Any ideas anyone ?
    Oct 2011
    Australia
    If it was spelt like that you have serious problems Often when starting with a low battery after a cold night messages like this can occur. If it happens after each start then you have a problem.
    Those two messages do occur when the plug at the back of the ABS modulator is removed. The ABS light also turns on.
    Jack
    Feb 2009
    Bondi
    DSC message
    Someone suggested the full steering lock both ways,did that and all is back to normal............
    Cheers Paul
    Mar 2007
    Birnam Range, qld
    sounds like low voltage, battery could be on its way mate.
    Feb 2009
    Bondi
    TD-6 MESSAGES
    Thanks Guys
    I will see if it comes on again in the morning.
    It was cold last night.Could be the battery.
    Paul
    Aug 2010
    Sunbury, VIC
    It does sound like your battery may be on the way out - the steering sensor calibration that you did is needed when the ECU powers down below a certain level, or is disconnected for maintenance.
    How old is the battery in it? About 5 years seems to be all they last - these cars are very power hungry beasts.
    Manly QLD
    I agree. Battery is on it's way.
