Thread: Tyre pressures
    Oct 2011
    Burra NSW
    Tyre pressures
    An age old question, but what sort of tyre pressures should I run 18in tyres for off road work? This is the first vehicle I've had with 18in rims, thinking about the 25psi mark for general off road work? Any ideas? Vehicle is a td6 hse rangie.
    Aug 2010
    Sunbury, VIC
    Good question, I haven't got around to getting 18's for mine yet, but it is on the list, so this is an answer I would like to know as well. Your guess sounds about right, hope someone else here can confirm this.
    Cheers - Gav
    Jan 2012
    Geelong Vic
    TYre pressures L322 TD6
    Hi, I travelled Odnadatta Tk, Ghan track, Cobourg Rd and Gulf road last year on 255/60/18 GG's, kept pressure to 26/7 psi, without any drama. I do try to keep speed down over rocky sections and was worried about depth of rubber between road and rim. I have now fitted a set of 65 profile BFG's for my next trip to give me a little more peace of mind. I was unable to get any reliable info on recommended pressures before making the trip last year and arrived at my conclusion by looking at tyre clearance at different pressures before settling on 26 etc. I will have to do the exercise all over for the BFG's unless someone else has any ideas ? Also I tow a trailer so the car did not have a lot of weight in the rear.
    Cheers, Peter
    May 2011
    Hi Guys,
    Thought I'd weigh in on this one as well. I tend to keep my normal road going pressures at around the 36-40psi mark depending upon end and load. This is according to the placard and tyre manufacturer recommendations.
    According to the latest information from Land Rover the pressures should not be lowered below 80% of the placard pressure for tyres with a profile of 60% or less.
    This means that if your rear tyres are at 40 psi then they can be brought back to 32psi, the fronts from 30psi down to 24psi. This may be conservative based on conventional thinking but it should provide a fair safety margin to help reduce the likelihood of pinching the tyre and rim. Sand is a whole different ball game but even then anything below 24psi is asking for trouble with the possibility of separation from the rim getting greater exponentially with every pound less.
    I travelled for a couple of weeks through the Flinders Ranges and parts north to Lake Eyre last year and had my pressures around the 26-30psi mark depending on the terrain without a single hiccup. I may have been lucky. That was on GG AT2s (255/60R18).
    Of course the old maxim still applies. The tyre pressure comes down, the vehicle speed comes down accordingly.
    I personally work to a simple 75% rule as the math is mostly easy (3/4x). I never go below this unless in dire times.
    That's my 5c worth anyway.
    Iain
    Iain
    VK3BIT
    03MY Range Rover HSE Td6
    Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
    LROCV DTU member
    Oct 2011
    Burra NSW
    Thanks guys, I took the rangie out for it's first serious low range drive today, on nearly stuffed pirrelli 18in tyres, I ran them at 32 psi all round as the terrain was a lot of sharp rock, steep climbs, and some very wet red clay.
    After owning a defender for the last 15 odd years, the off road capability of the rangie was one of my biggest concerns. I need not worry, the rangie was awesome, traction ctrl came on only once, on a climb that my mates hilux with mud tyres had 5 goes on!
    I can't wait to wear the pirrellis out and put some new off road rubber on, going down the track of the GGs in standard size.
