Results 1 to 10 of 11
Thread: Door Seals
    Mar 2009
    Near Geelong, Vic.
    Door Seals
    I bought two of these yonks ago & have forgotten where they go.
    It's Britpart no.MWC6130
    I suspect they are for the bottom of the door jambs like so? They are FAR too long for the door tops.
    If so, this means the door seal that is sold by the metre goes up & over the door top & then down the side. I've done that & it looks a bit odd in the corners.
    Is this correct?
    Jan 2008
    Brisvegas
    Seals are straight, no bends. For the corners cut off with slight overlap.
    Top overlaps rear upright, front diagonal window overlaps top and door front vertical.
    CC
    Nov 2011
    How are you fixing the seal to the door surrounds? I was thinking of using some 3M double sided tape used for holding up pictures rather than riviting as the seal I have is just foam nothing really solid to rivet to.
    JDNSW's Avatar
    Quote Originally Posted by Ozdunc View Post
    The correct seal has a flat hole running the length of it. You put a strip of steel or aluminium in this. Rivetting has the advantage that it is a little more secure than any form of adhesive, although adhesives have improved significantly since 1958.
    Narre Warren South
    Clarke Rubber stock the Land Rover seal or you can pay a bit more and buy it through Scotts Old Auto Rubber (same part number).
    If your strips aren't too rusted you can cut/scrape off the old decomposed seal and slip them inside the new seal. All of mine have been too far gone so I need to get some gal strip cut.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Nov 2011
    Cheers. I have that seal and I figured thats how it would work, but couldn't see any mention of the strip in any LR parts suppliers websites, so wasn't sure.
    I might try the 3M tape and report back as it has a fair load rating and the seals not under much load at all. It will just depend on how good the adhesive is over the longer (and muckier) term.
    I'll rivet the lower strip as it's likely to get kicked.
    Now if it would just stop raining.
    JDNSW's Avatar
    Quote Originally Posted by gromit View Post
    Colin
    Ones I had to replace I found that the steel strapping used for holding things on pallets etc was ideal. It is not galvanised, but then neither was the original. It should not get wet unless the seal is damaged.
    Oct 2010
    Yarra Valley Victoria
    I got mine from Scotts auto rubbers and glued them in place with Sikaflex 11FC, fantastic stuff sticks like you know what to a blanket
    Mar 2009
    Near Geelong, Vic.
    I got mine from FourWheelDrives in Blackburn.
    It has U-section soft metal core that fits on the lip around the door jamb then I compressed it progressively with vice grips.
    Narrogin WA
    I bought mine from Paddock, they have the strip inside them, it will be interesting to see if they handle the UV light,
    Cheers Charlie
