Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: ID a 80'' help please
    TOJO 12HT Guest
    Ok i know this will b a long shot, but its all iv got atm.
    Iv got these 2 80''s n on one theres a plate with these numbers on it ( THE ROVER CO. LTD. CAR No: 06106485 )
    ill also try post up pics later
    Thanks Loui
    East-South-East Girt-By-Sea
    1.20 MB
    80" soft top
    Sent to Duncan & Phelps dealer in West Wyalong 1/5/1950
    customer Trenerry
    Engine 06106959
    Ign Key MRN9
    This 80" has a non-fishplate bumper, narrow front springs, the wide transom with "sprung shovel" seatbacks, 5" Butler headlamps behind the grill panel and yellow button freewheel unit transfer box.
    If fitted the hoodbows should have the curved top.
    Diana
    Caboolture
    If it helps mine is car number R06101688 and was destpatched 'In' 13/09/1949 and despatched 'out' on 11/10/1949.
    1.20 MB
    Quote Originally Posted by Mick-Kelly View Post
    Hi Mick
    Your 80" differs from Loui's 80 in that your 1950 model was built in 1949 while Loui's is a 1950 build.
    Also other differences, your vehicle is a ring pull freewheel unit, bakelite hand brake handle, flat top hoodbows and fishplate chassis/bumper.
    Diana
    BTW: Louis, if the second car doesn't have an ID, then you should be able to find the chassis number on the flat top of the LHS engine mount on the chassis. There may be two numbers but we need the long one.
    TOJO 12HT Guest
    80" soft top
    Sent to D & Phelps 1/5/1950
    customer Trenerry
    Engine 06106959
    Ign Key MRN9
    Diana
    Man thats amazeing, how u know all that from a few numbers. thanks heaps
    Yeah your right its got real narrow springs, full grill (lights gone tho
    wat looks like a green chassie, black painted front window sorounds, park lights in bulkhead, no external door handles
    motor is missing tho but its got a pto
    thanks again for your fast help mate regards loui
    1.20 MB
    Quote Originally Posted by TOJO 12HT View Post
    Good refererence sources!
    1.20 MB
    You can try Anthony Pearson, Classic and Vintage Bulbs in Adelaide for the Butler headlamps.
    For a reasonable alternative you can use tractor headlamp reproductions for the grey Fergy TE20 tractors They were fitted with the same Butler lamps, but make sure that you get hi-low beam types. Otherwise you can fit 5" H4 or sealed beam inserts into the butler style housing.
    TOJO 12HT Guest
    wish it only needed lights!! Haha
    maybe a chassie n motor for a start or ill be pushin the old girl all the time
    TOJO 12HT Guest
    Hi Mick
    Diana
    ) got it (i think lol) 06109272
    1.20 MB
    Hi Louis
    Unfortunately that is not a NSW vehicle so we don't have date and customer details, using close NSW vehicles it is likely the vehicle was sold late June or during July 1950.
    Interestingly with all the changes that happened during the 80" models, the two vehicles you have acquired should have exactly the same specifications in all areas. Not many 80" restorers have that benefit, usually having a number of differences between vehicles.
    Diana
