Thread: Knocking Sound
    Mar 2012
    Thirlmere
    Knocking Sound
    Hi i have just started to get a slight knocking noise from the back of my 91 disco. Only in 1st/2nd when going slow around corners gets a bit louder if turning up a hill . Any suggestions?
    St Helena,Melbourne
    4.28 MB
    Unijoint , A frame balljoint- check balljoint first.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2012
    Thirlmere
    Just went for another drive with a mate and the sound is coming from the front so i think it might be cv's .
    I thought CV's clicked when they failed I would say A fram ball joint or a fail bushing
    mormans....
    if its a nice even continuous click most likely its CV/s or a UJ. hard to check without pulling the hub down so thats one for preocess of elimination
    if its a clunk on and off then its most likely tcase lash or the ball joint but it can also be the locating bushes on the axle for the locating arms or radius rods. check the bushes by prying with a large screwdriver and the ball joint by applying the hand brake hard, selecting neutral then rocking the vehicle back and forth by hand.
    if its a little random then its a failing wheel bearing the quick check for that is if it quiets down under brakes. to eliminate this completely jack the wheels up one at a time and check for rim rock. anything more than 1mm or so at the rim lip is out of spec and requires a bearing check and adjust.
    Mar 2012
    Thirlmere
    Will be jacking it up tomorrow. But noticed on drive today it has a continuos click when turning on take off , if i coast around corner with no accelaration the sounds goes away. Starting to think that this is cv's . If so does anyone know the best place to buy from for cv's and wheel bearings
    Mar 2011
    Cooktown, North Queensland
    Question
    Easy check, I know you said originally noise from the rear, then determined front, have you checked the rubber/fabric donut (if fitted) on the rear prop shaft to diff drive at the rear diff flange?
    Because the vehicle is constant 4X4 any noises are hard to isolate to either end.
    It'sNotWorthComplaining! Guest
    mormans....
    Nah mormans have that bicycle chain noise, if it's knocking it could more like be those pesky Jehovas, or the Optus door to door pest
    Quote Originally Posted by salty View Post
    that is most definately the CV.
    MR automotive for your parts.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by It'sNotWorthComplaining! View Post
    Could be those Jehova's that i almost reversed over a couple of weeks ago, i tried again but they were too quick .
    1974 VW Kombi bus
