The diff pinion height should not change if you are using the same pinion height shims and the same pinion .
I would tend to leave the pinion height the same as it was, if you are reusing the same pinion gear or the diff may become very noisy.
The bearing preload shims are different to the pinion height shims as you no doubt know. In this case I would just set up the bearings to the correct preload ., but you had better be very very sure that you have the inner and outer races both seated properly.
IMHO these are 2 different issues, that should be treated separately. I have seen so called exact replacemnet bearings being significantly different to the original ones.
I will give a caveat here that I have only reassembled 2 diffs, and one (Porsche 924 turbo) I had end up having reset by and expert as the bearing preload depended on the cases matching and the bearings were different , and more recently I rebuilt a Rover diff successfully.
Rovercare is the expert on this so perhaps PM him.
Regards Philip A
  Reply With Quote Originally Posted by Warb
