Results 1 to 10 of 26
Thread: Pics - D2 rear wheel carrier
    aptfab Guest
    As promised to a couple members there are some pics of the D2 rear wheel carrier being built. Will have finished pics later this week. You can see the rear bar has integrated recovery points, jerry can holders, jacking points, and spare tyre provision.
    Ben
    Oct 2010
    Near Adelaide
    Looks good, any chance of "automatic" opening with the rear door? My wife thinks it is a hassle to move wheel then door. Also $$$?
    Nova
    Sep 2010
    melton, vic
    Quote Originally Posted by aptfab View Post
    Ben
    Is there one for a d1 and does the rear bar come with it as well and the big one cost ..
    aptfab Guest
    Well... We will be working on the D1 version once we clear the D2 from the shed, ideas have been passing the sketch pad for 12 months so it won't take long to get the first model up and running.
    We will be offering the rear bars with different options, bar only, bar with single swing away and bar with twin swing away.
    The plan is to have the single swing away open with the rear door, we have successfully done this with the defenders but due to the angle of the arc of movement the Disco rear doors take we still have a bit more design and trialling to complete.
    As far as pricing goes, I would expect the following :
    Rear bar $850
    Rear bar with single swing away $1700
    Rear bar with twin swing away $2300
    Ben
    NSW SW Slopes
    How do you get the catches to hold the carriers closed against the bar? They appear to be pulling the carriers away from their pivots rather than towards the bar.
    aptfab Guest
    We preload the latch with hardened rubber insulators so positive pressure is applied before its in its resting position. As a result the latch is under tension and the swing away is pulled toward its mating surface. cheers Ben
    NSW SW Slopes
    I've been on the lookout for suitable catches for a RWC that I will build for my D4. I've seen those but haven't been able to work out a way to get them to clamp the bracket against the bar. ARB's style of catch works well but I haven't seen any for sale.
    aptfab Guest
    check out the ues website.. Welcome to UES hope it helps
    schnitzel Guest
    Will be very interested to see how this all goes (esp the single swing out with the door... I've got a photo of one in the US - PM me with your email if you want me to send). I'm quite keen to do this to my D2... Keep the photos and updates coming!
    SW of Geelong
    I might be able to help you with latches.........Rijidij Off Road wheel carrier components.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
