Results 1 to 4 of 4
Thread: Snatch points
    Jul 2011
    perth
    Snatch points
    Iv got hook up points on my bull bar is it safe to snatch off these points or are they only for winching. i don't want to be one of those idiots that rip the bull bar off.
    South Sydney
    Generally not, unless it is specifically designed for the load (beefy steel), i'd play it safe and get soe chassis points, specifically for snatching, unlees you want to beef up the bullbar, which would be equally as good.
    Will
    Jul 2011
    perth
    It is the factory one so it is quiet beefy and has 4 bolts holding each side. Two in the side and two in the top.
    South Sydney
    Well a snatch recovery point is made out of 12mm+ steel plate if that gives you an idea of the froces involved. Personally i wouldn't snatch off one of them, but i only ever snatch off towbars anyway, if it's a front recovery it's winched. And i've never needed recovering, only helped others.
    Will
    ADIT: And when i say towbars, i don't mean on the ball, the strap is in the reciever with the pin through the loop
