I just did a search on the STC1698 number, and the info you have on the bottom is correct (They also referenced the 560775 number as well). And the pic is the same as well.. So if you order the STC1689 part number you will get the correct one. And you should be able to get it at any LR part places.
I did a search on some of the supplier sites here, and none of the part numbers came up. Sounds like getting it from the UK is the only option..
Wolf
Reason: Adding more info.
1972 - S3 LWB (109) Wagon - Parts
1974 - S3 LWB (109) Wagon - Jess - (Registered)
1975 - S3 LWB (109) Wagon - Parts
1978 - S3 LWB (109) Wagon - Parts
1979 - S3 SWB (88) Utility - Aurora (TBR)
2014 - Defender (110) - Cher (MY15)
