Results 1 to 10 of 16
Thread: higher tow bar required
    Jan 2012
    hello Together,
    just received our camper trailer and the standard tow bar bottomed out
    after going over a small log (not in off road height admittedly) but looking at it, it's so damn low that I wonder what LR engineers though when designing it.
    I know there are some alternatives but can find them anywhere in the forum (did a couple of searches for higher towbar, alternative towbar etc)
    Does someone know a good way to have a tow bar fitted with more ground clearance?
    Thanks a lot
    Steve
    Dec 2008
    Prospect 2148
    Steve
    From what i've heard (since I don't tow), try searching for Mitch Hitch
    Mike
    Adelaide - Torrens Park
    Jan 2012
    thanks guy's that’s what i was after
    Dec 2008
    Melbourne, AU
    As an interim, have you tried inverting your tounge to get a bit more height?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by aferrier View Post
    As an interim, have you tried inverting your tongue to get a bit more height?
    Yes, but apart from speaking funny it hasn't raised the height of the tow hitch at all
    Dec 2008
    Melbourne, AU
    Quote Originally Posted by skuilnaam View Post
    I sw that one coming the moment I hit the submit button
    Sep 2010
    You could also have a look at a 'rapid' hitch which is fully adjustable or one of the adjustable Hayman Reece hitches. Both are cheaper alternatives to changing over to a Mitchell Bros hitch, just depends which one suits best.
    Sadie Guest
    I've just converted to the Mitch Hitch and now have a surplus Hayman Reece height adjustable tongue if you want to save some $$. PM me if you're interested...
    Jan 2012
    bought the Mitchell Brothers hitch should arrive next week, I increased the height with a extender from repco but my issue is the ground clearance and that is not solved by it.
    so hope the Mitchell B will do the trick
