Yes, Gav the main engine fan is a viscous unit.
That's an electrically operated unit that changes the viscosity of the fluid and acts just like a clutch to engage and disengage the fan. It's more than just a simple temp reactive fluid these days.
It relies on inputs from the engine ECU regarding air temp, engine temp, vehicle speed, engine speed and probably a whole bunch more inputs as well. It (ECU) then decides whether to trigger the fan clutch or not.
The electrically powered fan(s) is/are for airflow through the AC condenser system.
Clear as mud? Yep, it was for me too initially. There's a fairly good writeup in RAVE, from my ailing memory.
Anyway this thread was about the inline pump (and related errors). Sorry for the brief hijack.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
