Before you buy a set - check yours because normally it is only the front one that goes. They are often on ebay and cost less than $100. Alternatively any good Landrover parts supplier will have them.
 Fossicker
						Fossicker
						Wheres the best place, price wise, to get a set of rear diff mounts in the Perth area? I am in Port Kennedy, would prefer to pickup but dont mind having them posted. Thanks
 Fossicker
						Fossicker
						Thanks gary, I have checked and it does look like its the front one thats going/gone. Also there are some rub marks on the floor/heat shield above the prop shaft/diff joint.
I have seen them on ebay for that price, posted from the UK, just wondered if anyone knew anywhere more local.
I have read that you need to undo the lh and rh ones to get the front one in so thought may as well change them while I was there.
